Madcyclist Posted Tuesday at 07:49 PM Report Share Posted Tuesday at 07:49 PM I've recevied my Skip 1 and it seems my experience is more stable that most. While the other devices work well the Humax FVP-5000T is sluggish - the buttons all work but they can't be pressed in quick succession. If you're trying to navigate the TV guide you have to pause for a few seconds between each button press and even then the input is ignored at times. Has anyone else experienced this? I can help debug this as I've got the original remote and a Flirc so I can recored the original IR. I'm happy to check the recorded codes vs. the database if there's a way to get the codes out of the database in a suitable format (since this seems to be all buttons not just specific ones so it could take some time.) Thanks! Quote Link to comment Share on other sites More sharing options...
c.dennis Posted Wednesday at 02:07 AM Report Share Posted Wednesday at 02:07 AM I'm also experiencing just the same with my Telenet cable box, no problems with my Philips TV. Quote Link to comment Share on other sites More sharing options...
Nathan Posted 12 hours ago Report Share Posted 12 hours ago On 1/24/2023 at 1:49 PM, Madcyclist said: I've recevied my Skip 1 and it seems my experience is more stable that most. While the other devices work well the Humax FVP-5000T is sluggish - the buttons all work but they can't be pressed in quick succession. If you're trying to navigate the TV guide you have to pause for a few seconds between each button press and even then the input is ignored at times. Has anyone else experienced this? I can help debug this as I've got the original remote and a Flirc so I can recored the original IR. I'm happy to check the recorded codes vs. the database if there's a way to get the codes out of the database in a suitable format (since this seems to be all buttons not just specific ones so it could take some time.) Thanks! If you have a flirc, can you open the Flirc app, open the Device Log, and enable IR Debugging. Then record your original remote. In particular, record the same button pressed a few times. Then paste the output in a txt file with a note saying which codes go with which button. Then upload here. Quote Link to comment Share on other sites More sharing options...
