August 21, 20232 yr comment_30344 Hi! I have not been able to find an existing codeset that will work with the Skip and my receiver from 2010. I've recorded the remote button clicks through the IR debugging feature, and the text file is attached. Could y'all work your magic and send me a Skip codeset to match, please? One thing I noticed is that multiple presses of each button give different codes; I assume that's a rolling code security feature like my garage doors have, but I'm hoping y'all can still hook me up. :) Thanks much! G Sony STR-DA5500ES Receiver.txt Report
August 25, 20232 yr Author comment_30453 Gave it a try, but no luck, I'm afraid. Do we expect Yamaha codes to work with Sony devices? Thanks again! Report
August 25, 20232 yr Solution comment_30455 I don't know why I did that. I attached the wrong codes. Here is the correct one. Sony - STR-DA5500ES.json Report
August 26, 20232 yr comment_30471 my pleasure, it's in the newest release just published as well. Report
