HolyRoller Posted January 21 Report Share Posted January 21 Just received my Skip and am trying to set it up. Got the batteries in, USB cable connected, software downloaded, but it isn't connecting. I named my remote "Home" and it just says "Home is not connected" at the bottom left corner of the app. Was it also supposed to come with a USB dongle? I'm just wanting to use it with Plex so it shouldn't be too bad. Anyone offer any help? Thanks! Link to comment Share on other sites More sharing options...
theboomr Posted January 22 Report Share Posted January 22 This is an ongoing problem with the app on both Windows 10 and 11, not everyone experiences it but some of us do. @jason has been working on it, you can check the thread here for more info. 1 Link to comment Share on other sites More sharing options...
jason Posted January 28 Report Share Posted January 28 We're working on a fix and found the problem. Hang tight. 1 Link to comment Share on other sites More sharing options...
HolyRoller Posted February 4 Author Report Share Posted February 4 (edited) Thanks, Jason! Possible dumb question here @jason, but was the 1s supposed to include a USB dongle? Mine didn't come with one and I was thinking it would, but maybe I just misunderstood. Edited February 7 by HolyRoller Link to comment Share on other sites More sharing options...
Nathan Posted February 7 Report Share Posted February 7 On 2/4/2023 at 4:20 PM, HolyRoller said: Thanks, Jason! Possible dumb question here @jason, but was the 1s supposed to include a USB dongle? Mine didn't come with one and I was thinking it would, but maybe I just misunderstood. Need a bit of clarification here. The Skip 1s comes with a usb cord to connect to your computer. It does not come with a Flirc USB, unless you ordered one with the Flirc USB. If you did and didn't get it, let us know. Link to comment Share on other sites More sharing options...
HolyRoller Posted February 22 Author Report Share Posted February 22 (edited) On 2/7/2023 at 12:47 PM, Nathan said: Need a bit of clarification here. The Skip 1s comes with a usb cord to connect to your computer. It does not come with a Flirc USB, unless you ordered one with the Flirc USB. If you did and didn't get it, let us know. Thanks Nathan, I went ahead and ordered a USB dongle. My Skip 1s is working great now with the update. Could you point me in the right direction on how I can control my Windows Plex software with the 1s and USB receiver? Edit: Spoke too soon, got it working. Thanks! Edited February 22 by HolyRoller Link to comment Share on other sites More sharing options...
Nathan Posted February 22 Report Share Posted February 22 15 hours ago, HolyRoller said: Thanks Nathan, I went ahead and ordered a USB dongle. My Skip 1s is working great now with the update. Could you point me in the right direction on how I can control my Windows Plex software with the 1s and USB receiver? Edit: Spoke too soon, got it working. Thanks! Awesome, good work and thanks! For those who happen to run across this, you can add a PC, brand Flirc, model Plex, and your Flirc USB should *just work.* Link to comment Share on other sites More sharing options...
