No control over Leds Brightness & Leds Timeout ?
Is it possible that Leds Brightness and Leds Timeout do not change when syncing with the remote ?
Just sent Leds Brightness 100% to remote + synced and afterwards 0% + synced again and in both cases the leds had the same brightness, same result with 25, 50 and 75%.
Same with Leds Timeout, standard on 1s, but they light up for 3s (actually 3,42s starting from pressing the button, with a deviation of 0,03s), when using the remote, same effect here, changing value in to 3s or 0s always light up the leds for 3s. Used 0.9.4 from the site, without errors or sync problems.
Edited by sb5
  • 2 months later...
