mechman Posted March 31, 2024 Report Posted March 31, 2024 Hi, We've been happily using the remote for a couple months now and it's honestly been great. Unfortunately, as the title says, I've run into a problem and can't seem to troubleshoot my way out of it. We just purchased a new tuner box and I wanted to add it to the remote. Since the box wasn't on the list, it needed to be added like our projector. Not a problem, except the record button was greyed out on the app. I haven't updated the software since I got the remote - so I decided install the latest beta. The record button was still greyed out, and I wasn't prompted to update the software - so I followed the linked instructions. That didn't work, so I tried the manual firmware update. I looked away from the updater after starting it, and it said disconnected, so I figured it was done. Unfortunately, I forgot to put the batteries back in before running the updater. I'm not sure if that caused the problem, but since then I have not been able to connect to the remote. Connecting it to a computer does not show that a device is connected - i have tried two windows computers and a linux machine. I have tried a couple different USB cables. Nothing doing. With batteries in the light blinks red three times when a button is pushed. When plugged into the computer without batteries, the light blinks red three times when a button is pushed. But the computer shows no indication that a device has been connected. Did I fry something inside, or is it stuck in some weird bootloop? Thanks in advance for your help. Dan Quote
mechman Posted April 1, 2024 Author Report Posted April 1, 2024 Making a mention to @Nathan and @jason to bring this on the radar. Reading through a bit more of the forums I came across this post that seems to align with my issue. If this was caused by my mistake I'll pony up for a new one, just looking to make sure I'm not missing anything obvious. Thanks! Quote
jason Posted April 2, 2024 Report Posted April 2, 2024 17 hours ago, mechman said: Making a mention to @Nathan and @jason to bring this on the radar. Reading through a bit more of the forums I came across this post that seems to align with my issue. If this was caused by my mistake I'll pony up for a new one, just looking to make sure I'm not missing anything obvious. Thanks! It's borked, send me a pm. Quote
jason Posted July 15, 2024 Report Posted July 15, 2024 12 hours ago, astevens999 said: Count me in with this issue... Posted in another thread, but try the below. I did it with one of my remotes, and it fixed it. Temperature dependent... Put it in a plastic bag, put in the freezer for 5 minutes. Take it out and try again. It's a cold solder joint, manufacturing fixed in a subsequent build. Please let me know if that works. Honestly, I'm much more conservative with firmware updates on this product. I have night sweats about bugs that drain batteries so I'm favoring stability over features right now. Quote
