rolandbreedveld Posted August 20, 2023 Report Posted August 20, 2023 I want to use the Skip to controll My Logitech Harmony HUB is this possible? Quote
Nathan Posted August 22, 2023 Report Posted August 22, 2023 I don't think so. The HUB doesn't have any kind of IR input, does it? Quote
rlively Posted December 27, 2023 Report Posted December 27, 2023 Not that I know of. Is there any option for an IR-to-bluetooth emulation for the hub or some other clever solution using other products or coding? I have hubs that are working but harmony remotes that are not. Quote
Uzi2 Posted December 29, 2023 Report Posted December 29, 2023 If the Harmony Hub is working, you can control it with your phone or tablet using the app. Quote
rlively Posted December 29, 2023 Report Posted December 29, 2023 6 hours ago, Uzi2 said: If the Harmony Hub is working, you can control it with your phone or tablet using the app. Yes, I do use the harmony app to do that, but the experience is better with a remote which is why it would be great if the Skip 1s could send commands to the hub. Quote
Benjamin1971 Posted December 29, 2023 Report Posted December 29, 2023 (edited) Quick Answer The Harmony Hub is primarily RF controlled. Direct control with the Skip is not supported possible. Not Quick Answer In theory, you can set up a Raspberry Pi with Home Assistant and a FLIRC as a translation layer between IR and IP control for the Harmony Hub. The FLIRC would receive the IR command from the Skip, triggering a Home Assistant action. The main challenges include potential latency from the translation process and the need to establish actions and connections. I haven't done it, but below are a couple of links to get you started if you want to try. * Harmony Hub/Home Assistant Integration * Controlling Home Assistant with an Old Remote Edited December 29, 2023 by Benjamin Metzler Quote
