Denon AVR X6400H Mode Game, Mode Music, Mode Cinema do not work
I am trying to setup Skip1s to control my AVR Denon X6400H, I have mapped the Mode Music, Mode Cinema, Mode Game to digits 1 , 2, 3 respectively and have removed the default action on those keys, these keys do not perform any action when pressed
Edited by Shiv
  • Shiv changed the title to Denon AVR X6400H Mode Game, Mode Music, Mode Cinema do not work
Can someone let me know when Flirc can provide support for AVR X6400H ? I do not want to return the device just because the DB was no up to date.
Hello Jason,
Many thanks for looking into this.
I tired fishing around for these modes IR commands.
The following HEX code for Movie Mode works, I created the JSON profile file (attached) with commands and was able to get them to work.
0000,0070,0000,0032,0080,0040,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0030,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0030,0010,0030,0010,0ACE
Could not find working HEX codes for Music Mode, Game Mode, Pure Direct.
I tried the IR Debug feature of flirc but was unable to make any headway using IRScrutinizer.
Example For Music Mode this is what Flirc Debug spits out ( one observation the below code changes every time i repeat the process.
-21229000
+3312 -1664 +485 -313 +485 -315 +484 -1148 +484 -314 +485 -1148 +484 -314 +485 -1148 +484 -314 +485 -314 +484 -1148 +485 -314 +485 -314 +484 -1148 +485 -1148 +485 -314 +484 -314 +485 -314 +484 -314 +485 -314 +484 -314 +484 -314 +485 -314 +484 -1148 +485 -314 +484 -1149 +484 -314 +485 -315 +483 -314 +485 -314 +484 -1149 +484 -314 +484 -1149 +484 -314 +484 -315 +484 -1148 +484 -315 +484 -1149 +484 -315 +483 -315 +484 -315 +484 -1149 +483 -315 +498 -1135 +484 -325 +473 -1149 +484 -1149 +484 -1150 +483 -1149 +484
-74000
+3312 -1664 +485 -314 +484 -314 +484 -1149 +484 -315 +484 -1148 +485 -314 +485 -1149 +484 -315 +483 -315 +484 -1149 +484 -314 +484 -315 +484 -1149 +484 -1149 +484 -314 +484 -315 +484 -314 +484 -315 +484 -314 +484 -315 +484 -315 +483 -315 +483 -1150 +483 -315 +484 -1149 +483 -315 +484 -315 +483 -316 +483 -315 +483 -1149 +484 -315 +484 -1149 +484 -315 +483 -315 +483 -1149 +484 -315 +483 -1150 +483 -316 +483 -315 +483 -315 +503 -1130 +484 -330 +468 -1150 +483 -316 +541 -1092 +483 -1149 +483 -1150 +483 -1149 +484
-74000
+3314 -1663 +485 -314 +484 -314 +485 -1148 +485 -314 +484 -1149 +484 -314 +484 -1149 +485 -314 +485 -314 +484 -1148 +485 -314 +484 -314 +485 -1148 +484 -1149 +484 -314 +485 -314 +484 -315 +484 -314 +484 -314 +484 -315 +484 -314 +485 -314 +484 -1148 +485 -314 +484 -1149 +485 -314 +484 -314 +485 -314 +484 -314 +484 -1148 +485 -314 +484 -1149 +484 -314 +484 -314 +484 -1149 +485 -314 +484 -1149 +484 -315 +484 -315 +484 -334 +464 -1149 +484 -315 +495 -1138 +484 -323 +475 -1149 +484 -1149 +485 -1149 +484 -1150 +483
I do not yet know the basics of these IR codes and what the above numbers mean, will start learning that soon this week.
What I do know is the code for these modes should end with ***, 0ACE ie they seem to be first created by koseikyo for Denon.
Not sure of any of these help attaching the current json i have cooked up. Please note only Movie Mode works, the codes for Music, Game modes no not work as I think the device is expecting koseikyo codes and internet is filled with Sharp codes which end with **,0679
Let me know if you need me to try something out.
Cheers,
Shiv...
PS: Would it be possible to add a Standard start and end log for the IR debugging feature of FLIRC, not sure if this will cause some other issues on your end but this will aid in future. Offcourse a tool which allows training the device with custom hex codes would be awesome :)
Denon-AVRX6400H-AV.json
curious, where did you find this one?
try irtools.exe/irtools
Ships on every platform and can output a number of different formats and has decoders.
As we jump into learning/decoding/etc, I will be extending our tools and most likely making them public. This is what we are working on: https://www.dropbox.com/scl/fi/vu3dxznffmjk069wjht9c/walk-through-recording.mp4?rlkey=foi48kn5gducs10g7bxcqip65&dl=0
Hey Jason,
Got that HEX code from the excel at this link http://assets.denon.com/DocumentMaster/us/Denon Master IR Hex.xls
Somehow it accidentally works for a few commands but does not work for others example Mode Movie works but Mode Music does not work :)
Called Denon tech support and as expected they denied maintaining any sheet and were not willing to provide me any HEX code info.
That UI looks perfect, i guess we would find the solution for the issue at hand before its release, but it will be effective for next user who stumbles upon this issue.
Thanks,
Shiv...
Edited by Shiv
Hey Jason,
Tried it same issue as the incomplete Json file i created Movie Mode works but Music mode does not work.
            "label": "Movie Mode ",/////////// < Works
            "protocol": "PRONTO",
            "code": "0000,0070,0000,0032,0080,0040,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0030,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0030,0010,0010,0010,0030,0010,0010,0010,0010,0010,0010,0010,0030,0010,0030,0010,0ACE"
            "label": "Music Mode", //////////< Does not work
            "code": "0000,006D,0000,0020,000A,001E,000A,001E,000A,0046,000A,001E,000A,001E,000A,001E,000A,0046,000A,0046,000A,001E,000A,0046,000A,001E,000A,001E,000A,0046,000A,001E,000A,001E,000A,0679,000A,001E,000A,001E,000A,0046,000A,001E,000A,001E,000A,0046,000A,001E,000A,001E,000A,0046,000A,001E,000A,0046,000A,0046,000A,001E,000A,0046,000A,0046,000A,0679"
Warm Regards,
Shiv...
Hey Jason,
Warm Regards,
Shiv...
Okay, try this
If this doesn't. Similar to before, give me a text file of the buttons you are trying to record and the flirc recording of them like you did previously. Example Contents:
MUSIC MODE
-74000
-74000
TV MODE
+3343 -1664 +485 -313 +485 -315 +484 -1148 +484 -314 +485 -1148 +484 -314 +485 -1148 +484 -314 +485 -314 +484 -1148 +485 -314 +485 -314 +484 -1148 +485 -1148 +485 -314 +484 -314 +485 -314 +484 -314 +485 -314 +484 -314 +484 -314 +485 -314 +484 -1148 +485 -314 +484 -1149 +484 -314 +485 -315 +483 -314 +485 -314 +484 -1149 +484 -314 +484 -1149 +484 -314 +484 -315 +484 -1148 +484 -315 +484 -1149 +484 -315 +483 -315 +484 -315 +484 -1149 +483 -315 +498 -1135 +484 -325 +473 -1149 +484 -1149 +484 -1150 +483 -1149 +484
-74000
+3312 -1664 +445 -314 +484 -314 +484 -1149 +484 -315 +484 -1148 +485 -314 +485 -1149 +484 -315 +483 -315 +484 -1149 +484 -314 +484 -315 +484 -1149 +484 -1149 +484 -314 +484 -315 +484 -314 +484 -315 +484 -314 +484 -315 +484 -315 +483 -315 +483 -1150 +483 -315 +484 -1149 +483 -315 +484 -315 +483 -316 +483 -315 +483 -1149 +484 -315 +484 -1149 +484 -315 +483 -315 +483 -1149 +484 -315 +483 -1150 +483 -316 +483 -315 +483 -315 +503 -1130 +484 -330 +468 -1150 +483 -316 +541 -1092 +483 -1149 +483 -1150 +483 -1149 +484
-74000
+3314 -1663 +485 -314 +444 -314 +485 -1148 +485 -314 +484 -1149 +484 -314 +484 -1149 +485 -314 +485 -314 +484 -1148 +485 -314 +484 -314 +485 -1148 +484 -1149 +484 -314 +485 -314 +484 -315 +484 -314 +484 -314 +484 -315 +484 -314 +485 -314 +484 -1148 +485 -314 +484 -1149 +485 -314 +484 -314 +485 -314 +484 -314 +484 -1148 +485 -314 +484 -1149 +484 -314 +484 -314 +484 -1149 +485 -314 +484 -1149 +484 -315 +484 -315 +484 -334 +464 -1149 +484 -315 +495 -1138 +484 -323 +475 -1149 +484 -1149 +485 -1149 +484 -1150 +483
Denon - AVR-X6400H.json
Hello Jason,
Music mode works !!! thanks you, I will need some more time to ensure other buttons work but for all practical home theatre purposes all I need are
Power ON / OFF
Mute ON/OFF
Volume UP / DOWN
INFO
Mode Movie
Mode Game
Mode Music
We are getting there almost :)
Could you kindly recheck the Game Mode HEX code, It does not seem to work.
Raw Signal from original remote when i press Game Mode is :
-42394000
+3259 -1717 +485 -314 +485 -312 +486 -1147 +485 -313 +485 -1147 +485 -313 +485 -1147 +485 -313 +485 -313 +485 -1147 +485 -313 +485 -313 +485 -1147 +485 -1147 +485 -313 +486 -313 +485 -313 +485 -313 +485 -313 +500 -298 +485 -313 +485 -324 +474 -1148 +484 -314 +486 -1146 +485 -313 +485 -313 +485 -314 +484 -1150 +483 -1147 +485 -313 +486 -1146 +486 -312 +486 -313 +485 -1147 +485 -314 +484 -1147 +486 -313 +485 -313 +485 -313 +485 -1147 +485 -314 +484 -1147 +485 -313 +485 -313 +485 -1147 +485 -1147 +485 -1148 +485
-74000
+3311 -1664 +486 -312 +486 -313 +485 -1147 +485 -312 +486 -1147 +485 -312 +486 -1147 +485 -313 +485 -314 +484 -1147 +486 -312 +486 -312 +485 -1147 +485 -1148 +485 -313 +484 -313 +486 -313 +485 -313 +485 -313 +484 -314 +486 -312 +485 -313 +498 -1135 +485 -324 +474 -1148 +484 -314 +486 -312 +485 -313 +485 -1147 +486 -1147 +485 -313 +485 -1147 +486 -313 +485 -312 +485 -1148 +485 -313 +486 -1147 +485 -314 +485 -314 +484 -313 +485 -1148 +485 -313 +484 -1148 +484 -314 +485 -313 +485 -1147 +485 -1147 +485 -1147 +485
-74000
+3312 -1663 +485 -314 +485 -313 +485 -1148 +484 -314 +484 -1148 +484 -313 +485 -1148 +485 -313 +485 -313 +485 -1147 +485 -313 +485 -314 +484 -1148 +485 -1147 +485 -314 +484 -314 +484 -314 +485 -314 +484 -314 +484 -313 +485 -314 +485 -313 +485 -1148 +484 -314 +498 -1134 +485 -324 +474 -314 +484 -314 +484 -1148 +485 -1147 +485 -314 +484 -1148 +484 -314 +484 -314 +485 -1148 +484 -314 +484 -1149 +484 -314 +484 -314 +485 -313 +484 -1148 +485 -314 +484 -1148 +484 -314 +484 -314 +485 -1148 +484 -1148 +484 -1147 +485
Warm Regards,
Shiv...
Edited by Shiv
9 minutes ago, Shiv said:
Hello Jason,
Power ON / OFF
Mute ON/OFF
Volume UP / DOWN
INFO
Mode Movie
Mode Game
Mode Music
-42394000
-74000
-74000
Warm Regards,
Shiv...
Thanks for recording the signal. Can you try this for Game Mode: 0000 006D 0032 0000 007E 003F 0012 000C 0012 000C 0012 002C 0012 000C 0012 002C 0012 000C 0012 002C 0012 000C 0012 000C 0012 002C 0012 000C 0012 000C 0012 002C 0012 002C 0012 000C 0012 000C 0012 000C 0012 000C 0012 000C 0012 000C 0012 000C 0012 000C 0012 002C 0012 000C 0012 002C 0012 000C 0012 000C 0012 000C 0012 002C 0012 002C 0012 000C 0012 002C 0012 000C 0012 000C 0012 002C 0012 000C 0012 002C 0012 000C 0012 000C 0012 000C 0012 002C 0012 000C 0012 002C 0012 000C 0012 000C 0012 002C 0012 002C 0012 002C 0012 0AFC
Game Mode is working with this code
I will test the rest and provide you with the updated working json for Denon AVR X6400H
Many thanks for your support on this topic.
