Can't get the remote to work w. my Sony Bravia TV & STR receiver
okay, factory reset the skip and that has helped a little.
My activity has 3 devices:
- sony tv - 4k UR2
- sony receiver - STR-ZA2100ES
- Nvidia Shield
The on/off on the tv works. However, that is the only thing that responds.
I have my shield set to both handle navigation and the media/music controls, and my receiver set to control my audio.
Any suggestions? I'm not totally surprised that the audio doesn't work (per the initial issue), but i am surprised my shield doesn't respond.
On 3/3/2023 at 6:12 PM, Nathan said:
Is this the Shield that can accept IR? If it's a more recent Shield, they don't have IR input and you need a Flirc USB.
Sorry for the delay as i've been away. I have the NVIDIA SHIELD TV PRO from 2019. I've been using my logitech harmony remote with it using the harmony IR blasters. The device resides in my AV closet along with my receiver. I have plugged the usb into the back of the device. I feel like i will need to purchase something else but not sure what that else is at this tim.
Edited by userdude
Ah, OK. Yeah, the Skip needs line of sight. There are IR repeaters out there that could help with this.
Sorry for being vague - i'm using the skip with line of site until i get it to work. Then i'll want to get an IR Repeater that works with it (if you have a suggestion that would be great).
For the shield, the USB port is back. I've tried pointing the skip at it from the back and the shield still does not respond. My receiver does not respond either. The tv is the only one that works.
Cheers.
Cheers.
You've mentioned the USB port a few times. Is the Shield being controlled with a Flirc USB?
So, I was just coming back to update you on what steps i've taken. So I pulled the Flirc dongle out and plugged it back into my computer and there were a few updates for it. I went to program it again using the updated shield config, but during the process, i'm running into problems with the mapping. When I walk through the configuration - it will ask for the directional pad and the select button, followed by the power button and menu button. However, when i select the power button on my Skip, the application seems to record multiple commands (or something like that) because it will accept that the power has been programmed, blink for the menu for a moment, and then ask for the home key. If i go back to the menu it says it's already been selected.
So here's where we are at -
The skip is turning my tv on and off.
The skip is working with my shield - but the home and menu buttons keep getting recorded as the same
The reciever is still not responding.
@userdude Ok. With regard to the Flirc USB, you should actually be able to File -> Clear Configuration, and that will solve a lot of problems. The Flirc is built already knowing some codes. If you clear the configuration on the Flirc, and then program the Skip 1s in the Skip App to work with Flirc - NVIDIA Shield, the Flirc USB should just work, no programming in the flirc app needed.
Regarding the other two devices, if you have a Flirc USB and the original remotes, we can record those remotes and create profiles for them. To do so, open the Flirc app, then File - Device Log. Then enable IR Debugging. Then go through and record each button and save the output as a text file with each button press labeled. Each button press will look something like:
+9051 -4416 +605 -511 +601 -1625 +606 -1626 +605 -1621 +605 -511 +605 -1625 +605 -1622 +609 -1621 +605 -1626 +605 -1626 +605 -1621 +606 -510 +605 -519 +597 -510 +606 -510 +605 -1622 +605 -511 +605 -1625 +605 -511 +605 -1622 +605 -510 +606 -510 +605 -513 +603 -510 +605 -507 +605 -511 +605 -1626 +606 -510 +601 -1626 +605 -511 +605 -1622 +605 -511 +554
-41
+9055 -2182 +554
We can turn that into pronto codes and get you a fully working remote. Eventually, this will all be automated and part of the Skip App, but we're not there yet.
-41
+9055 -2182 +554
Great, i will give that a shot. a little busy over the next two days but it's high on my want to do list ;-). If you have a recommended IR blaster (or a way to repurpose the Harmony IR blaster), please do let me know.
