terrykj Posted January 20, 2023 Report Posted January 20, 2023 I haven't been able to get my TV Sony KD-85X85J or my Sony Home Theater Receiver STR-DH770 to respond. Which code group should I be using? Quote
jason Posted January 21, 2023 Report Posted January 21, 2023 Make sure you select the right category for each. There is a test button, we are adding visual feedback and improving this. Another update should come soon with a newer database as well. Quote
terrykj Posted January 21, 2023 Author Report Posted January 21, 2023 I tried the test button while trying to program the remote but none of them seemed to work with either device. It does works fine with the Directv receiver. Quote
jason Posted January 28, 2023 Report Posted January 28, 2023 I'm going to prioritize learning soon, I'm not quite sure because our database is done without specific models. But as soon as we get the next release out, I'll have the ability to learn as the next feature. Or a reverse lookup. Quote
v0idmain Posted February 2, 2023 Report Posted February 2, 2023 Hello! I'm in the same boat with my Sony Bravia 2015, remote id RMT-TX100U. Created activity, watch tv, add tv/projector, Sony, All model types, also tried extended codes. TV does not respond, also tried test option. Let me know if I can help figure it out. Thanks. Quote
Nicolas M. Posted February 20, 2023 Report Posted February 20, 2023 Same here Trying to use my Sony Home Theater Preamp STR DN1080. I've tried all Home Theater available in "Audio" section and all STRxxx in "Misc" section. Any idea ? Since all my devices are behind this home theater, i'm quite blocked right now :( Quote
Nicolas M. Posted February 21, 2023 Report Posted February 21, 2023 I will create a new topic as suggested Quote
