I'm trying to create a sequence to my power button for Activity A that will turn on the TV and change the input to antenna.
I'm assigning two actions to the button, the first one is "Power On" and the second one is "Input Antenna".
It seems that doesn't matter what I do, only the first action is actually sent by the remote. Whatever I put as the first action is the one activated.
I tried setting a delay of 4 seconds on the first action in the sequence (Power On) so that the second action (Input Change) is triggered 4 seconds after. I pointed my phone's camera on the remote so I can see when there's IR activity -- I can see that it's only sending 1 command, nothing happens 4 seconds later.
Really stumped here.
Appreciate any help.
