Problem programming Play & Pause for WMC
Having trouble trying to program Play and Pause for Windows Media Center. i seem to be able to program all functionality, except for these 2. GUI says "recorded successfully", but when i try to use the buttons, nothing happens.  I've also tried using different buttons on the remote (ie not Play & Pause on the remote), but with the same result.
I've tried 2 different remote controls, i'm able to program all functionality i need, except for Play and Pause.
flirc firmware: 2.3
flirc gui: 1.2.2
remotes used: Tivo (series 2) and Samsung Smart TV remote
any ideas?
Fast Forward & Rewind work fine, Up, Down, Left, Right, Enter, Mute, Home all ok. Basically everything except for Play & Pause
i'm trying to not have to use a keyboard, just a single existing remote. Flirc seemed cool that i could use an existing remote. And it's working great, mostly, right up until i fast fwd the ads, but can't stop it by pressing "Play", or using "Pause".
there is a problem with windows media center, I'll try and address that shortly, but I'm tied up. I believe it has something to do with the ctrl+p, the ctrl needs to be sent, and then the p. I send them simultaneously. A bit ridiculous, but it's on my list of stuff to fix.
that sort of makes sense ... sorta. happy to help sort this out when you have time. appreciate it.
I think you missed the "GUI" portion there.
I was suggesting to, instead of using the WMC interface that already has the media keys where you simply select Play/Pause and press the button on your remote, that you go to the Full Keyboard layout in the Flirc GUI and try programming your keys from there and see if it works better. I was not suggesting that you use an actual keyboard.
I actually have a similar problem.  Though mine is for the INFO button and the SKIP BACK and SKIP FWD commands.
Initially I couldn't program PLAY or PAUSE either like the OP and just like Deadpool suggested, programming via the "full keyboard" layout in the GUI fixed that.  Unfortunately this didn't work for my other buttons.  This makes using MediaBrowser very difficult as it doesn't seem to use the standard Rewind of Fast-Forward commands but uses Skip Back and Skip Forward.  So I essentially have no easy way to navigate when using it.
Is the 2.3 firmware relatively new?  I feel like I'm on 2.2 but will have to check when I get home, could this have fixed the issue?
"gui" keyboard made all the difference! got it all sorted, thanks all. and yes, the wmc keyboard shortcuts are pretty cool.
Play = Ctrl+Shift+P
Pause = Ctrl+P
Would you mind seeing if you can get the following commands working for you:
Skip Back = Ctrl+B
Skip Forward = Ctrl+F
Shortcut Menu = Ctrl D
what were the shortcuts you programmed? I'd like to update the wmc controller if it makes sense.
I think one of the key ones missing:
The "Green Button" command = Windows Key+Alt+Enter
Live TV = Ctrl+T
Recorded TV = Ctrl+O
I programmed them in the Full Keyboard layout, but if you look into adding to the Windows Media keyboard those would be helpful.
i was able to get a buttons working for:
Windows Key+Alt+Enter (mega!)
Live TV = Ctrl+T
Guide = Ctrl+G
but not
Skip Back = Ctrl+B
Shortcut Menu = Ctrl+D
Live TV = Ctrl+T
Guide = Ctrl+G
but not
Skip Back = Ctrl+B
Same exact thing for me, thanks for checking it out.
Jason, is there anything that can be done to fix this?
These are tough not to have when playing MKV files in MediaBrowser3 since the standard MCE "Rewind" and "Fast Forward" don't work and you have to use "Skip Back" or "Skip Forward."  I'd rather not rely on a separate keyboard for this.
The Info button is a really hard one not to have.
How about the media keys? Do those work? They have ff and next track previous track and rewind
Wow, thanks!  Using the Media Keys keyboard got the Skip Back (Previous) and Skip Forward (Next Track) working!  Any suggestions for the Info command (Ctrl+D)?  Also known as the "Shortcut Menu" in WMC.
I'd like to also confirm that play, stop & pause do not seem to work in media center (firmware 2.3 ui 1.2.2).
I tried the media center binding page and also the media keys binding page to no avail.
Fast forward, and backwards seems to work fine.
Setting up the those keys through the full keyboard page does work.
Edited by blah1
