iBobZero Posted March 9, 2023 Report Posted March 9, 2023 For some reason I can't seem to get the remote codes to work with my Pioneer VSX-325 receiver. I have tried the attached codes all none of them seem to work. Any suggestions? Quote
iBobZero Posted March 9, 2023 Author Report Posted March 9, 2023 So after some further tinkering got everything but powering off to work. Quote
jason Posted March 9, 2023 Report Posted March 9, 2023 6 minutes ago, iBobZero said: So after some further tinkering got everything but powering off to work. Thanks for the update. Can you clarify what you had to do to fix everything so I can incorporate these changes? That may help me figure out why power off wont work as well. Quote
iBobZero Posted March 9, 2023 Author Report Posted March 9, 2023 (edited) So when troubleshooting the first thing I noticed was the "Test Device" during the wizard did not work at all for any of the Pioneer options. As well as once I proceed to the Summary section the Pioneer did not show up for an option for power up or power down. But I was able to assign the power up option to the power button. However power down did not work regardless of what option I picked. As well as I noticed my mute also didn't work on any of the device groups until I figured out the default assignment to mute was "mute off" instead of "mute toggle" Edited March 9, 2023 by iBobZero Quote
jason Posted March 10, 2023 Report Posted March 10, 2023 3 hours ago, iBobZero said: So when troubleshooting the first thing I noticed was the "Test Device" during the wizard did not work at all for any of the Pioneer options. As well as once I proceed to the Summary section the Pioneer did not show up for an option for power up or power down. But I was able to assign the power up option to the power button. However power down did not work regardless of what option I picked. As well as I noticed my mute also didn't work on any of the device groups until I figured out the default assignment to mute was "mute off" instead of "mute toggle" Very helpful, thank you so much. Very strange, all buttons work except the power toggle? Quote
iBobZero Posted March 10, 2023 Author Report Posted March 10, 2023 So I can’t seem to get my Pioneer to power off with any of the Power Off commands or the Toggle Power. I figured going through each one would eventually take but for some reason didn’t for me. I will say I do have a Logitech Harmony which does work for powering it off. But not sure if that helps you any. Quote
jason Posted March 10, 2023 Report Posted March 10, 2023 4 minutes ago, iBobZero said: So I can’t seem to get my Pioneer to power off with any of the Power Off commands or the Toggle Power. I figured going through each one would eventually take but for some reason didn’t for me. I will say I do have a Logitech Harmony which does work for powering it off. But not sure if that helps you any. It does help, I'll record and compare the code. Do you have a flirc USB? If not, do you have the device/model you have on your harmony? Quote
iBobZero Posted March 10, 2023 Author Report Posted March 10, 2023 I do have a flirc usb. Just let me know what I need to do to get that data for you. However in the meantime I do also have the harmony information. Which is currently set as HTP-074. Quote
jason Posted March 10, 2023 Report Posted March 10, 2023 1 hour ago, iBobZero said: I do have a flirc usb. Just let me know what I need to do to get that data for you. However in the meantime I do also have the harmony information. Which is currently set as HTP-074. Fire it up, go to advanced, enable IR debugging, and then Press the problematic button on Skip1s. Then do it on harmony. Export the file for me and I'll take a look. I have a different sensor in the skip1s that captures the fundamental frequency, and due to the interrupt latency, I need to do re-write this all using DMA. I'm working on it. For now, we'll manage with what we have. Just post that here and I'll start looking. Quote
iBobZero Posted March 10, 2023 Author Report Posted March 10, 2023 See attached for the log. First press as requested was the turn off command from the skip1s, the second was from the harmony. I have also attached another where I have selected power toggle (just incase you need that too). Hopefully that helps. Let me know if there is anything else you need. my_flirc_log_ibobzero_pioneer_off.txt my_flirc_log_ibobzero_pioneer_powertoggle.txt Quote
jason Posted March 11, 2023 Report Posted March 11, 2023 Try importing the attached using the following guide: What I actually found was your Power Toggle and Power off command from harmony are identical. I've added the power toggle in this file. Please let me know if that fixes the power for you, and we'll take a dig into what's going on. Thanks for all the helpful info and logs. Pioneer - VSX-325.json Quote
