nak0604 Posted March 4, 2023 Report Posted March 4, 2023 I have been trying to get admin mode enabled on the skip app but it doesn't seem to be working on windows 11. I have placed the config file you have floating around in multiple disscusions in the specified place %localappdata%\Packages\SkipApp_sddpyax1dmvqm\LocalState\ There is no wrench or panel to access it. Quote
jason Posted March 4, 2023 Report Posted March 4, 2023 54 minutes ago, nak0604 said: I have been trying to get admin mode enabled on the skip app but it doesn't seem to be working on windows 11. I have placed the config file you have floating around in multiple disscusions in the specified place %localappdata%\Packages\SkipApp_sddpyax1dmvqm\LocalState\ There is no wrench or panel to access it. You have to restart the app Quote
nak0604 Posted March 4, 2023 Author Report Posted March 4, 2023 (edited) 2 hours ago, jason said: You have to restart the app I did, several times actually Edited March 4, 2023 by nak0604 Quote
LewisPattJr Posted March 13, 2023 Report Posted March 13, 2023 The file location is different for the newer beta build. Trying placing the config.json file here (at least for the 0.9.70 build): ...\AppData\Local\Packages\SkipApp_sddpyax1dmvqm\LocalState The close and restart the software. Quote
nak0604 Posted March 14, 2023 Author Report Posted March 14, 2023 4 hours ago, LewisPattJr said: The file location is different for the newer beta build. Trying placing the config.json file here (at least for the 0.9.70 build): ...\AppData\Local\Packages\SkipApp_sddpyax1dmvqm\LocalState The close and restart the software. You do realize that is the same location that I put in right? Only difference is it looks different. Windows takes you to the exact same folder. Anyways, I just tested this and I can confirm after updating to 0.9.70 it is working now. 1 Quote
LewisPattJr Posted March 15, 2023 Report Posted March 15, 2023 On 3/13/2023 at 9:39 PM, nak0604 said: You do realize that is the same location that I put in right? Only difference is it looks different. Windows takes you to the exact same folder. Anyways, I just tested this and I can confirm after updating to 0.9.70 it is working now. Honestly, I completely glossed over that. Sorry... I had just had the same problem and my brain just went 'ooh, ooh, I can help with that' and jumped into action. Glad it's working now at least. 1 Quote
