January 1, 20179 yr comment_12951 Hi,I have two problems with my flirc. 1.) I often get multiple key presses (the key hangs until i press an other key) when I only press one key on the remote (One for All Simple 4). I already tried to play around with the interkeydelay. It gets better with a long delay but is not completely solved. (Firmware 3.8)2.) Then I tried to record the keys again in flirc but always when I try to record a key it states immediately that a key is recorded but I did not press any key. I think this happens after a firmware update. I tried it on two windows pc's in two rooms. I also set the noice canceller feature but then I am not able to record any keys with the remote. I am not sure what changed because in the past I was able to record a key. Maybe the problem 1 is resulting from problem 2 that the flirc picks up a lot of ghost commands? Or maybe it is defect? Thanks in advance for your help,Stefan Edited January 1, 20179 yr by dienstfuchs Report
