I have a harmony 900 remote and I want to use it to control both PS4 for movie (found a site with guidelines on how to setup Flirc with Harmony) and HTPC.
I assume I will need to have one Flirc on each of device but how does it work with you have one remote pointing at two different Flirc (PS4 and HTPC on same shelf)
Please advise.
If you have two devices, they need different codes. So set your harmony to have different profiles and record one for the first flirc and use the second for the other flirc. Then use the harmony software to customize your remote. Otherwise both devices will respond. Hope that makes sense.
