January 6, 20251 yr comment_39107 I have a device with two buttons that toggle: Power button alternates on/off Mute button alternates mute/not mute I can't duplicate this behavior with the skip. Is there a way to setup one button to alternate between two states, as the original remote does? Report
January 8, 20251 yr comment_39152 Yes, recently published and only available to a few buttons. By default, it's enabled on the 'power' button always. It will be automatically enabled if toggle buttons are available for either the play/pause or mute button. You can however enable them if it doesn't automatically do so. See the following: CleanShot 2025-01-08 at 11.01.04.mp4 Report
January 20, 20251 yr Author comment_39357 Still trying to get it to work. Haven’t succeeded yet. One of my devices doesn’t show a buttons panel in the app and I can’t figure out what the issue is. Report
January 20, 20251 yr comment_39358 13 minutes ago, firedog said: Still trying to get it to work. Haven’t succeeded yet. One of my devices doesn’t show a buttons panel in the app and I can’t figure out what the issue is. can you post a screenshot? Report
January 22, 20251 yr Author comment_39377 Screenshot. The Electra TV in the YES+ TV activity has no arrow to the right and no button panel that pops up. Report
