November 12, 20241 yr comment_38250 My Skip 1s has to be pointed directly at my cable box (Samsung SMT-C5320) to function past 6ft of distance. If I'm up close, I can point the remote at an angle and everything will work just fine. If I'm further away, it doesn't matter if I'm aimed at the sensor, I either have to be dead-on (as in 90 degrees perpendicular) to the cable box or it does not work. Whereas the remote that came with the cable box can be pointed at the wall and it'll still work. This seems like a power issue, but I've tested new batteries and I have three other devices at the same distance and they work just fine (flirc, lg tv, yamaha sound bar). I've tested with another same-model cable box and experienced the same issue, dead-center or no input with the Skip 1s. I suspect it's a programming issue, where the IR signal the remote is sending is not strong enough but I don't know how to troubleshoot that. Any advice? Report
November 12, 20241 yr comment_38252 Can you send a pic of the remote that it came with that works? Could be something else. Modulation frequency or timing. Report
November 12, 20241 yr Author comment_38265 15 hours ago, jason said: Can you send a pic of the remote that it came with that works? Could be something else. Modulation frequency or timing. Picture attached. Here's a link to the remote: https://www.optimum.net/FAQ/#/answers/a_id/3974 Please let me know if I can do anything to assist the process; I'm in IT and I've got a lot of patience for troubleshooting. Report
November 13, 20241 yr comment_38268 I bought a remote, I'll take a look when it comes. Send that config when you have a chance. Report
November 13, 20241 yr Author comment_38277 Here's the config I'm using. A is set for the cable box although I have some controls on B and C as well. HTPC Skip 1s.skip Report
November 21, 20241 yr Author comment_38368 On 11/12/2024 at 11:58 PM, jason said: I bought a remote, I'll take a look when it comes. Send that config when you have a chance. Let me know if there's anything I can add to the process, config is posted above. Report
