October 29, 20241 yr comment_38002 I'm looking to automate a non-standard controller and I'm new to the libir decoder format. I've been trying to replay the recording below using sendir for automation and tried using the decoder to get it into a format it can play back. It does play back but the device I'm trying to control is not responding as I'm pasting in a command like below. I'm definitely doing something wrong, but it's not obvious what I'm missing. Any help would be greatly appreciated! Recorded IR Data +9056 -4481 +576 -523 +600 -497 +574 -523 +600 -497 +599 -499 +599 -547 +525 -523 +575 -522 +598 -1633 +600 -1633 +600 -1633 +576 -1657 +599 -1633 +575 -1658 +575 -1657 +575 -1657 +600 -1632 +575 -523 +575 -522 +575 -1657 +575 -1656 +575 -523 +574 -522 +575 -522 +574 -524 +573 -1658 +612 -1620 +574 -523 +599 -498 +574 -1657 +575 -1657 +575 -1657 +599 -40000 +9044 -2240 +574 -97000 +9053 -2238 +575 Command I'm Using sendir --raw="+9069 -4483 +517 -583 +515 -584 +515 -584 +515 -583 +516 -583 +515 -583 +515 -583 +515 -584 +545 -1689 +516 -1720 +516 -1720 +516 -1720 +516 -1719 +516 -1719 +516 -1719 +516 -1719 +516 -1720 +516 -583 +516 -583 +547 -1690 +516 -1727 +510 -583 +516 -584 +546 -553 +546 -555 +545 -1689 +516 -1721 +516 -583 +546 -554 +546 -1689 +517 -1720 +516 -1720 +517" Report
October 29, 20241 yr Author comment_38009 flirc_util.exe $ version 3.27.16 FW Version: v4.10.5 SKU: Flirc 2.0 [dori] Branch: release Config: release Hash: 0xF7261C8C Report
December 10, 20241 yr comment_38680 ensure the multiline data is formatted correctly (using \n for line breaks) and your system can handle it. Test it, and you should be good to go! Report
