Argon Audio SA1
Hi there,
just received my Remote and was looking for my stereo amplifier, which support IR Inputs:
Argon Audio SA1
https://argonaudio.com/products/sa1
I want to control mainly the volume / mute with that together with my TV + FireTV (via Flirc USB stick) which already works so far.
If other buttons like switching channels of the amplifier (bluetooth, aux,...) would be available would be a plus --> I've attached a layout of the original remote controller for a better understanding -> I could imaging using a second channel or the number pads of the Skip 1s, but thats to be tested then :-)
Would love to hear from you if thats possible - I could only find one other Argon Audio device which unfortunately does not work from what I tested.
Also, is there a way to train a remote controller myself via the Flirc USB receiver and then import it onto my Skip 1s?
Thanks in advance!
lennard
