September 7, 20232 yr comment_30623 Hi I just got my new remote today and have set it up with my tv and roku just fine but when I go to try and set it up with my Vero 4k it doesnt seem to work. I tried setting it to Kodi device and it doesnt do anything. Is there something I am missing in the setup to make it work? Report
October 3, 20232 yr comment_31019 On 9/7/2023 at 1:15 PM, Jarritos said: Hi I just got my new remote today and have set it up with my tv and roku just fine but when I go to try and set it up with my Vero 4k it doesnt seem to work. I tried setting it to Kodi device and it doesnt do anything. Is there something I am missing in the setup to make it work? Okay, after some digging, here is how to do it. Vero primarily supports bluetooth out of the box. But here are instructions by the creator, which should be really easy to do. Add Microsoft Windows MCE profile to the Skip 1s It wont auto-work with your Vero 4k Select the Microsoft Windows MCE profile under the remote menu None of us have this box, please let us know how that goes. Report
October 3, 20232 yr Author comment_31023 How do I add Microsoft Windows MCE profile to skip 1s? Are you talking about using the skip app? Report
October 3, 20232 yr comment_31024 44 minutes ago, Jarritos said: How do I add Microsoft Windows MCE profile to skip 1s? Are you talking about using the skip app? Yes, if you already have your activity setup, you can click on the gear icon while hovering the activity: Click on "Wizard" to jump back into the activity. Go to Add Device Click on Set Top Box You can find Manufacturer: Microsoft, Model: MCE Media Center Code Group 2 Please keep me posted. Report
December 19, 20232 yr comment_32473 Hi, I bought the Skip remote from your store and tried to configure it with my Vero4K... it doesn't work. In the decoder configuration, Microsoft Windows MCE is selected... nothing happens. Sony TV + ADB Ultrabox 4K works well. I would like to ask how the switch from (A) to (B) works (for example) ? When I select (A) then power on remote - TV + Decoder is starting When I want to turn on Vero4K+TV then Decoder should to turn off but TV stay on. It doesn't work. TV is turning off. I swithed from Logitech Harmony so on Logitech i can set specific behavior. Report
