July 4, 20233 yr comment_29607 I have been asked for previous versions of the old plastic version of filrc. I do not support this product anymore, use at your own risk, and I will not be responsible if it is bricked. If the upgrade fails, restart the GUI, it should restore the latest firmware. I can dig up previous versions, but it's going to take me some time, please explain what went wrong and why. v3.12.00 Fix for bad descriptor v3.11.0 adding firetv harmony codes adding sheild harmony codes shield pro updates and support v3.9.0 ability to determine sku v3.8.0 Updating built in mappings for logitech v3.7.0 fix for windows media center (enable sequence modifiers) adding ability to do browser home v3.6.0 updating firmware updated built in harmony xbmc profile up arrow down arrow zoom+ small step back toggle full screen red, green, yellow, blue power off streacom 'power' key will now work if computer is on, not just off fix for built in profiles that caused wrong keys to be sent changing default interkey delay for new algorithm interkey delay settings improved protection of read only memory in rom adding built in support for harmony firetv profile flirc_gen1_v3.6.0.bin flirc_gen1_v3.7.0.bin flirc_gen1_v3.8.0.bin flirc_gen1_v3.9.0.bin flirc_gen1_v3.11.00.bin flirc_gen1_v3.12.00.bin Report
August 5, 20233 yr comment_30059 Thanks Jason. I'll do some testing and report back to share the wealth. Report
