adampiecubed3 Posted February 2, 2023 Report Posted February 2, 2023 Good Morning, Just received my Skip yesterday, happy to have it and its great to use with a few exceptions. When I use an activity, I use it for a while. For example, I might be using activity B for a couple of hours. I have found that within 10-30minuites or so without me even touching the remote, the remote will change it self back to activity A. This issue has been pretty consistent for me. I'm not sure if there is a logging process I can use to send you feedback on this but I'm happy to send you what you need.
jason Posted February 2, 2023 Report Posted February 2, 2023 I have a fix ready. I’m doing a couple more fixes and features and will have an update for you. Sorry if that’s been annoying. 1
adampiecubed3 Posted February 2, 2023 Author Report Posted February 2, 2023 No problem, thanks for the work on this! Definitely way better than my old remote. 1
jason Posted February 8, 2023 Report Posted February 8, 2023 Thank you. I’m done. We’re all doing testing now on it. I have a number of fixed. 1
