o_cee Posted January 25, 2014 Report Posted January 25, 2014 Hi Upgraded to v2.2 (from some of the newer RCs on the forum), and now my Flirc doesn't respond to keypresses sent by my Harmony remote (with the Flirc XBMC profile) unless I first send a command which is taught in the Flirc (using some Samsung TV for additional commands since the XBMC profile is so limited). So, if I only send commands which are part of the builtin profile, it never works. Quote
jason Posted January 25, 2014 Report Posted January 25, 2014 Make sure in advanced settings, built-in profiles is not disabled Quote
o_cee Posted January 25, 2014 Author Report Posted January 25, 2014 "Builtin Profiles" is ticked. I guess I could disable and enable it, but it's that it's not working, it does work after sending another command. Quote
o_cee Posted January 25, 2014 Author Report Posted January 25, 2014 ./flirc_util version Flirc Version v1.2.0 [v1.2.0] 2.2 12-18-2013 [0x052EC67A] ./flirc_util settings Settings: sleep detection: Enabled noise canceler: Disabled inter-key delay: 6 state: 0 builtin profiles: Enable Memory Info: keys recorded: 2 keys remaining: 167 memory used: 1% Recorded Keys: hash key --------- --- 688F44A e E587F44A delete ./flirc_util dump 63 Reading: 0000 00 11 A6 80 05 4A F4 88 06 00 08 4A F4 87 E5 00 0010 4C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ./flirc_util status Last upgrade attempt: Error What about that last one? Quote
o_cee Posted January 25, 2014 Author Report Posted January 25, 2014 A minor correction; the two trained buttons, e and delete, are using IR commands from the Harmony XBMC profile which isn't detected by the Flirc: BigStepBack and BigStepForward. Does that make any difference? It worked on earlier firmwares without problems. Quote
Jep Posted January 25, 2014 Report Posted January 25, 2014 Same problem here. Just upgraded firmware and no keys responding in XBMC. Didn't try to teach any commands and press them first. Flirc Version v1.2.0 [v1.2.0] 2.2 12-18-2013 [0x052EC67A] Settings: sleep detection: Disabled noise canceler: Disabled inter-key delay: 3 state: 0 builtin profiles: Enable Memory Info: keys recorded: 0 keys remaining: 169 memory used: 0% No Keys Found Last upgrade attempt: Error Quote
Bochi Posted January 26, 2014 Report Posted January 26, 2014 Okay guys, I have the same issue with my Harmony 650 and flirc 2.2, none of the builtin profile's keys are working at all. I guess I am blind, but the subject says there's a workaround but I can't see any in this thread? What's the easiest way to downgrade to the previous firmware version? Why aren't the firmware files available as standalone anymore, only bundled with the GUI? While I understand that it's way more comfortable to have it bundled with the GUI and make it upgrade automatically I think they should still be available as seperate files, for emergency situations like this where it is necessary to go back to the previous version... Cheers Bochi 1 Quote
Bunkadoo Posted January 26, 2014 Report Posted January 26, 2014 I just bought a Flirc to use with my Harmony 700 and XBMC on a Win 8.1 x64 machine and I'm having similar issues with XBMC (and now nothing else) getting any commands from the Flirc. I installed the Flirc profile on my Harmony 700, but could never get any keys in XBMC to work. I was able to do the minimalist command recording to verify the Flirc was working. Based on the advice in another thread, I forced a firmware update to v2.2. But now the Flirc doesn't seem to be working at all with any remote (or on another computer), let alone with XBMC. And now when I load up the GUI, the firmware version always displays as "v-16.-16" Trying to force update the firmware again locks up the GUI. And if I read correctly there's no other way for me to change the firmware now? Quote
jason Posted January 26, 2014 Report Posted January 26, 2014 Sorry about this guys. I figured out the problem. Released an update. Upgrade to v2.3 and the problem will be fixed. Quote
bridlington Posted January 26, 2014 Report Posted January 26, 2014 Hi! I tried to login and it failed. It says my firmware version is -16.16 :wacko: Quote
bridlington Posted January 26, 2014 Report Posted January 26, 2014 sorry not login but upgrade. Quote
jason Posted January 26, 2014 Report Posted January 26, 2014 sorry not login but upgrade. Close the GUI, and reopen it. Are you on windows? There is a bug, and I can't reproduce it enough to figure out what's going on. So any help on that would be appreciated. However, it's just reading the version wrong, the device is fine. Quote
Bunkadoo Posted January 26, 2014 Report Posted January 26, 2014 I'm also having no luck with the upgrade. On Win 8.1 64-bit. It always displays -16.-16 as the version, even after restarting the GUI. When trying to upgrade the firmware it says Your firmware version is: -16.-16 The latest firmware version is: 2.2 And then locks up the GUI when trying to upgrade. Here's some flirc_util.exe output that replicates the commands above. I'm new to all this so let me know if you need anything else, and thanks for any help! >flirc_util.exe version [E] determine_iface(101): version not supported, loading def: ver1 Flirc Version v1.2.0 [v1.2.0] [E] fl_ver1_version_str(866): usb tx result > 0: -2 (null) >flirc_util.exe settings [E] determine_iface(101): version not supported, loading def: ver1 Settings: sleep detection: NA noise canceler: Enabled inter-key delay: 0 state: 0 builtin profiles: NA [E] get_size(103): Error reading high byte of size -3.000000 >flirc_util.exe dump 63 [E] determine_iface(101): version not supported, loading def: ver1 Reading: 0000 Error >flirc_util.exe status [E] determine_iface(101): version not supported, loading def: ver1 Last upgrade attempt: Error Quote
jason Posted January 26, 2014 Report Posted January 26, 2014 I'm also having no luck with the upgrade. On Win 8.1 64-bit. It always displays -16.-16 as the version, even after restarting the GUI. When trying to upgrade the firmware it says Your firmware version is: -16.-16 The latest firmware version is: 2.2 And then locks up the GUI when trying to upgrade. Here's some flirc_util.exe output that replicates the commands above. I'm new to all this so let me know if you need anything else, and thanks for any help! >flirc_util.exe version [E] determine_iface(101): version not supported, loading def: ver1 Flirc Version v1.2.0 [v1.2.0] [E] fl_ver1_version_str(866): usb tx result > 0: -2 (null) >flirc_util.exe settings [E] determine_iface(101): version not supported, loading def: ver1 Settings: sleep detection: NA noise canceler: Enabled inter-key delay: 0 state: 0 builtin profiles: NA [E] get_size(103): Error reading high byte of size -3.000000 >flirc_util.exe dump 63 [E] determine_iface(101): version not supported, loading def: ver1 Reading: 0000 Error >flirc_util.exe status [E] determine_iface(101): version not supported, loading def: ver1 Last upgrade attempt: Error Incredibly helpful, I know what's wrong. Thanks a million. I'll post an update in a few minutes. Quote
o_cee Posted January 26, 2014 Author Report Posted January 26, 2014 Sorry about this guys. I figured out the problem. Released an update. Upgrade to v2.3 and the problem will be fixed. I can confirm that v2.3 fixes this issue for me, thanks Jason! Quote
jason Posted January 26, 2014 Report Posted January 26, 2014 No problem, so sorry about the trouble. Quote
gfondeur Posted January 26, 2014 Report Posted January 26, 2014 thanks a lot jason! problem solve, keep the hard work, Quote
jason Posted January 26, 2014 Report Posted January 26, 2014 I'm also having no luck with the upgrade. On Win 8.1 64-bit. It always displays -16.-16 as the version, even after restarting the GUI. When trying to upgrade the firmware it says Your firmware version is: -16.-16 The latest firmware version is: 2.2 And then locks up the GUI when trying to upgrade. Here's some flirc_util.exe output that replicates the commands above. I'm new to all this so let me know if you need anything else, and thanks for any help! >flirc_util.exe version [E] determine_iface(101): version not supported, loading def: ver1 Flirc Version v1.2.0 [v1.2.0] [E] fl_ver1_version_str(866): usb tx result > 0: -2 (null) >flirc_util.exe settings [E] determine_iface(101): version not supported, loading def: ver1 Settings: sleep detection: NA noise canceler: Enabled inter-key delay: 0 state: 0 builtin profiles: NA [E] get_size(103): Error reading high byte of size -3.000000 >flirc_util.exe dump 63 [E] determine_iface(101): version not supported, loading def: ver1 Reading: 0000 Error >flirc_util.exe status [E] determine_iface(101): version not supported, loading def: ver1 Last upgrade attempt: Error I posted an update, but I'm not sure it's going to fix this. This is probably a different problem. Ping me outside this thread, or start a new topic. Quote
Jep Posted January 27, 2014 Report Posted January 27, 2014 Thanks a lot, Jason. First update fixed the problem for me. This is the first time I use the built in profiles and the Harmony profile and I must says it's a great idea! Makes things much easier! :) Quote
jason Posted January 29, 2014 Report Posted January 29, 2014 Thanks a lot, Jason. First update fixed the problem for me. This is the first time I use the built in profiles and the Harmony profile and I must says it's a great idea! Makes things much easier! :) No problem, thanks for writing in and letting me know it's fixed. Quote
