Not sure if this is an issue with Flirc..
After a few hours of my windows 7 box running XBMC is idle (as i don't shut down the computer)
I just power off my amp and TV.
I use my remote to turn on the amp and TV.
Flirc is unresponsive for about a minute, I have to get near the Flirc usb stick with the remote for it to work, then after a minute I can sit back
down on the sofa and its fine.
I'm assuming the Flic goes into a sleep mode or low power mode?
Can this be disabled?
Other then this one issue, it works extremely well!  best thing since sliced bread.
Strange.
I'm sure Jason would be interested in debugging the issue with you at somepoint.
For the moment, which firmware are you using?
100% agree
I'm using latest beta release.
I've had this issue since day one.
I just re-installed Windows 7, same problem.  Nothing installed on it but XBMC.
The remote works great for my TV and Denon amp (powers them up, volume control etc) just that 1 minute lag on Flirc that I need to get close to it for it to receive the commands from the remote.
I've set the computer to not power down anything  (display, harddrives etc etc)  it's in high performance mode basically.
Maybe now that I'm thinking about it, could the USB have some sort of power saving mode?  I'll have to go through the windows settings some more.
Hmmm ok  I found a power saving mode for USB in device manager and it was enabled.
I disabled it and see if that will fix my issue,  I'll try it after a few hours of it idling and again in the morning.
I'll keep you posted.
