January 9, 20224 yr comment_20821 Hi all, I am trying to program URC MX-780 to power up/wake up my original MiBox (manually downgraded back to Android 8.0). After initial Xiaomi faulty upgrade of their MiBoxes (that made the box unstable and often unresponsive), I went back to using Roku which the MX-780 controls just fine. However, there is one custom app that cannot be loaded on Roku (Russian TV service that my mother watches). I was going to throw away the MiBox but found the tutorial on downgrading it back to original FW which worked and now I have fully functioning MiBox. I managed to upload Xiaomi Hex codes on the MX-780 and the remote controls the box just fine EXCEPT for the "power" command. The "Power Off" Hex code works just fine but I was unable to get "power ON" command to work. The same command ("Power ON") works 100 % of the time from the original BT remote. So I bought a USB Flirc hoping that I will be able to program it to reliably turn On the MiBox. Unfortunately, it was not the case: I tried programming under Kodi, Shield, Windows (wake command)- nothing worked so far. Have anyone managed to program gen.1 (original) MiBox to turn On/Off reliably using Flirc? If yes, what did you do? Thanks Report
January 9, 20224 yr comment_20825 Try the one under Controllers->Media Keys, as outlined in the photograph. Report
January 9, 20224 yr Author comment_20828 Hi Jason, Thanks for quick reply. I believe I tried that controller too. I erased everything from Flirc last night. Will try again, one by one from ea controller. Edited January 10, 20224 yr by m1964 Report
January 10, 20224 yr Author comment_20842 Hi Jason, spent about 2 hours trying to program the "Power ON" command: NO GO The command worked only for "Power OFF" but not for "power ON" when I programmed the button under Shield G.2 or media Keys controllers. Interestingly, that the list of IR Hex codes for MiBox contains a Hex code for discrete "Power OFF" that works every time on MX-780 but the Hex code for "Power ON" does not work well at all- it may work one time in 10-20 tries... Too bad - the MiBox ticks all my boxes otherwise. Report
May 14, 20224 yr comment_21984 Hi all, I am studying in matric and after secondary education, I want to learn to program practically. Please suggest to me the best way of online learning for me and where to start as well. Edited June 2, 20224 yr by dannylie12 Report
