Harmony Remote - "Quick" keypress not registering
Hi Guys,
I am having an issue with the flirc / harmony one / openlec combination.
I have setup the harmony using the flirc / xbmc combo in the my harmony software.  I have added a wake and suspend/shutdown key which works.  The one last issue I am having is as follows.
quick keypresses on the harmony don't seem to be registered by the flirc.  If I slightly hold down the key, that seems to work with no issues.  For example...I am on the main menu of xbmc...if I quickly tap the left arrow nothing happens, but if I press and hold it momentarily it works.
Are there settings that will help this behavior as it's annoying.
Regards,
Paul
