October 13, 20232 yr comment_31145 It's some time ago that there was the question, if there is a possibility to record commands with an original remote to produce .json files for devices. Is it possible, if yes, how? If no, is it planed and when will it be possible? Thank you! Report
October 15, 20232 yr comment_31179 I second this request, I have a ToneWinner AT-300 and want to add the codes in. I have a FLIRC USB and a Broadlink RM4 Pro and have tried learning the codes and creating a json for them with codes converted to Pronto and while it loads the codes and I can assign them they do nothing. Is there any update on the code learning feature and if not can we get instructions on how to use one of the devices I mentioned to learn and create a new device? I think that would be helpful for more then just me. Thanks for any help, Edited October 15, 20232 yr by Davedave1234 Report
October 15, 20232 yr comment_31180 I figured it out thanks to the below thread and in particular the third post from clmnt. First capture the codes from debug log and enter it into irscrutinizer I then get a code that does not work until I change each 0015 to 0016 and each 003D to 003E. Once that is completed the codes work as expected. I will get a full json with each code but there are 58 buttons so it will take some time. Once it is completed I will upload it here, or in a new thread dedicated to my device. In any case here is the process I used. 1: Use FLIRC with FLIRC USB in debug logs to capture the raw code +8980 -4413 +597 -489 +597 -1611 +597 -489 +597 -489 +596 -489 +597 -489 +596 -489 +597 -489 +596 -1611 +597 -489 +597 -1611 +597 -1610 +597 -1611 +597 -1611 +597 -1611 +596 -489 +597 -489 +596 -1611 +597 -1611 +597 -489 +622 -463 +596 -490 +596 -1611 +596 -489 +596 -1612 +596 -489 +596 -489 +596 -1612 +596 -1612 +596 -1612 +596 -490 +599 -1609 +596 -41000 +8978 -2213 +577 2: copy the code from the +8980 up to the -41000 and paste that into irScrutinizer using the "Paste & Scr" which generates the below code 0000 006D 0022 0000 0156 00A8 0015 0015 0015 003D 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003D 0015 0015 0015 003D 0015 003D 0015 003D 0015 003D 0015 003D 0015 0015 0015 0015 0015 003D 0015 003D 0015 0015 0015 0015 0015 0015 0015 003D 0015 0015 0015 003D 0015 0015 0015 0015 0015 003D 0015 003D 0015 003D 0015 0015 0015 003D 0015 0617 3: find and replace 0015 to 0016 and each 003D to 003E resulting in the below code 0000 006D 0022 0000 0156 00A8 0016 0016 0016 003E 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 003E 0016 0016 0016 003E 0016 003E 0016 003E 0016 003E 0016 003E 0016 0016 0016 0016 0016 003E 0016 003E 0016 0016 0016 0016 0016 0016 0016 003E 0016 0016 0016 003E 0016 0016 0016 0016 0016 003E 0016 003E 0016 003E 0016 0016 0016 003E 0016 0617 4: Add that to the respective button in the json file. Edited October 16, 20232 yr by Davedave1234 Report
