September 17, 20232 yr comment_30754 Hi I'm trying to use the Skip1 to control a LG Smart TV but I only can turn on/off, Channel change... but not to access to smartTV options. Is it possible... or would it in the future? Thank you in advance Report
September 17, 20232 yr comment_30759 1 hour ago, Pharizna said: Hi I'm trying to use the Skip1 to control a LG Smart TV but I only can turn on/off, Channel change... but not to access to smartTV options. Is it possible... or would it in the future? Thank you in advance Of course. Is your original remote Bluetooth with that wireless wand thingy feature? Report
September 17, 20232 yr Author comment_30762 No. My remote is IR and not BT. LG includes a standard IR remote (LG AKB75675311) their smartTV. There is another one (Magic control) MR20GA Magic Remote with that wireless wand thingy feature. Edited September 17, 20232 yr by Pharizna Changing picture Report
September 17, 20232 yr comment_30763 Awesome. I’ll help get this in quickly. Do you have a flirc USB? If not, I think I have this in my box of remotes at the office. Report
September 17, 20232 yr Author comment_30765 I think I had it... though I can't find it now Anyway, assuming I found it: How could it be used to "add" the missing options (like "GUIDE", "NETFLIX" or "AMAZON PRIME" to the Skip1? Report
