darebee Posted June 14, 2023 Report Posted June 14, 2023 I am using all with Harmony remotes and they have all been working for years. I just bought a new FLIRC to test and it has firmware 4.6.5 and still works fine. How can I get an older copy of the firmware? I think this would be easy for me. I no longer see any older firmwares published or I would not even be asking. Also, when launching Sling app the Ok\Select key will not launch Sling user choice. Again, all these things worked prior to updating to 4.9.7 firmware. Thanks,-Darren Quote
jason Posted June 14, 2023 Report Posted June 14, 2023 I’ll post that for you. Let me dig it up. can you post your config? It is possible you just need to re record those keys on the new firmware. But backup a copy first. Quote
darebee Posted June 14, 2023 Author Report Posted June 14, 2023 (edited) Jason, I tried that but every time it says the key is already present. Not to mention it's for the newer generation of the shield so Bluetooth remote. I know for sure this firmware will fix my problem. Nothing fancy in the config at all... I have tried the current key from the remote though. my_flirc_config_OfficeShield.fcfg Edited June 14, 2023 by darebee Quote
jason Posted June 14, 2023 Report Posted June 14, 2023 Sorry. I mean delete the key. And then record it again. Quote
darebee Posted June 14, 2023 Author Report Posted June 14, 2023 Jason, I was about to buy 5 new FLIRCs but you saved the day. I deleted the bad keys and re-learned them from the Harmony remote and everything is working fine. I then saved the configuration and loaded it to all 7 (I had 2 on old firmware) of my FLIRCS with upgraded firmware to 4.9.7 and we are all good. Thanks for your speedy response. -Darren Quote
