Problems with new profiles options
john9527
From the changelog/blog.....
[fw gen 2] - ability to disable/enable built in rom tables
[lib] ability to enable/disable rom tables
[util] updates for new everything
How do I use the option?   There is nothing in the gui app....the advanced tab still contains only a single greyed out entry.
Trying to use the command line app errors out.
Running Windows7 Pro.
(C:\Program Files (x86)\Flirc)
flirc_util.exe profiles
  builtin profiles: NA
flirc_util.exe profiles enable
enabling built in profiles
flirc_util.exe settings
flirc_util version v2.5.2 [v2.5.2+]
  Firmware: v4.1.2 [0x35B642F3]
Settings:
  sleep detection:  NA
  noise canceler:   NA
  inter-key delay:  NA
  seq. modifiers:   NA
  variant:          Flirc
  Memory Info:      NA
[D] lib/libcmds/cmds.c run_cmd(275): could not find command 'sku'
[D] lib/libtransport/transport.c _dev_send_cmd(235): Wrong response:
[D] lib/libflirc/firmware/fw_4.0.c get_config(85): command error
[D] lib/libflirc/firmware/fw_4.0.c fl_ver4_display_config(904): couldn't get config
  Records:          NA
