Logitech Harmony + Flirc on ubuntu => double button press and no response during playback
not sure if this is better of in the Bug section, so please move if this is true.
I recently bought a Flirc (along with a Dell Thin client) to replace my RaspberryPi4 (with soldered IR receiver) to replace my Kodi setup.
In principle it is working but I see these double key press issues. I tried reducing the delay in my harmony setup and used the Flirc profil as well but the problem persists. I attached the log from the Flirc app and you can clearly see the :e:25 almost every time.
Kodi is almost impossible to use this way. This happens on my Mac if I’m very close but also on my TV setup being much more far away from the Flirc dongle.
And there is a second issue with Flirc. Using my keyboard to control Kodi during setup of the ubuntu server I had no problems controlling Kodi.
When I started using Flirc and tried starting a video I noticed that around every second time the controls worked only until then. When the video is playing, I’m not able to stop/pause the video or get back into the menu. And this is true for the regular keyboard as well.
When I restart Kodi (systemctl) and without any further action the controls work fine again in Kodi. Not sure if this is a Flirc issue but I’m not seeing this with the regular USB keyboard.
Any ideas? Really appreciate your help.
my_flirc_config.fcfg my_flirc_log.txt
