December 3, 201312 yr comment_5266 hi, i'm using grub to choose between Windows and Openelec. If needed to switch it is always neccessary to use a keyboard. Isn't it possible to get flirc working already at this stage with some ir kb profile so the selection can be made using remote. Report
December 4, 201312 yr comment_5268 This sounds like it should work, once you have the Flirc programmed with your keyboard commands. As long as this program works with USB keyboards, don't know why it wouldn't, and doesn't expect one that is plugged into the PS2 port. Report
December 5, 201312 yr Author comment_5280 yes e.g. grub is working with usb keyboards. i'm still looking for working harmony ir keyboard profile. Report
