Kodi + Harmony 650 - play/pause not responding
ezelkow1
I set my harmony to use the flirc kodi profile in the harmony software.  I then set flirc to use the kodi profile and mapped each button manually to be sure. All my other buttons work fine except for play and pause. Ive tried erasing them and re-recording, the flirc software says they recorded, but when I hit the buttons on the remote I get no response in the flirc software
Highlighting another window to see the actual key presses I can see characters coming in for all keys except those two as well
So just wondering if anyone has run in to this or anyway around it? Hoping not to have to go and figure out the full keyboard mapping for kodi if I dont have to
  • 3 weeks later...
My Harmony 680 has the same issues with the Play and Pause.  It works fine with the 'old model' Flirc controller.  Any ideas from anyone?
I ended up switching mine to the boxee profile in the flirc windows app and then reprogramming the buttons. That has worked out fine for me so far with all buttons recognized
For Kodi I used the Kodi profile for everything except Play/Pause which I used Boxee and that seemed to work, however it seems that some of my remote buttons are acting like I pressed it twice  example, the 'back' button goes back two screens every time.
Yea I sometimes get the double key presses, it seems to be application dependent. Im using mine with a steamlink and kodi running through that. In the link interface itself I sometimes get double presses but once Im in steam streaming and kodi I dont see the double presses.  So maybe steam is filtering them out or something for me
This is only happening with the new flirc.  If I switch back everything works perfectly.  Real pain this is.
