UliBru Posted June 7, 2016 Report Share Posted June 7, 2016 Hello, I'm using the Streacom Flirc-SE and it works fine so far.As the computer is driven headless I need to connect from time to time by Microsoft Remotedesktop.So I have recognized that the Flirc commands by the remote control are ignored if Remotedesktop is active. Or better: Remotedesktop seems to stop the Flirc commands.Does someone know a workaround?Stopping Remotedekstop does not help, the computer must be rebooted to get Flirc working again. BRUli Quote Link to comment Share on other sites More sharing options...
yawor Posted June 7, 2016 Report Share Posted June 7, 2016 Flirc will only work with an active session. When you connect using Remote Desktop you probably log out or lock the local session.Maybe sending an enter key after logging out of Remote Desktop session could help, but I'm not really sure. You would need to connect a monitor and check what's going on. Quote Link to comment Share on other sites More sharing options...
