riley Posted August 26, 2015 Report Posted August 26, 2015 (edited) I'd like to buy a Flirc for my PC which is connected to the TV, but I'm not sure if it'll work for my use case. My main PC is connected to the TV via HDMI. Kodi is used as a TV front end so it's often in use by people even when I'm using the desktop for other things. Will flirc be able to send commands to Kodi while something else, like a game or web browser, has focus in Windows on another display? I'm planning on using it with a Harmony 510 if there's anything different about the Harmony profile that matters. Edited August 26, 2015 by riley Quote
yawor Posted August 27, 2015 Report Posted August 27, 2015 No. At least not alone. Flirc works as a keyboard so it sends keystrokes to the app in focus. Windows doesn't allow you to assign a specific keyboard to a specifc app.You could do this using some 3rd party software like AutoHotKey or EventGhots. If you search on the forum you'll find my thread about using Flirc as a Generic HID device in EventGhost. That way Flirc doesn't send standard keyboard key codes and you can intercept them using EventGhost and control Kodi using XBMC/Kodi plugin. Quote
riley Posted August 30, 2015 Author Report Posted August 30, 2015 Thanks for the response. I sort of assumed the answer would be along these lines but was hoping with its popularity with Kodi users it might be sending non-keyboard media commands. I'll look into those solutions you mentioned. I'm already somewhat familiar with using AutoHotkey for this sort of thing so I may go that route. Quote
KevinFonda Posted August 31, 2015 Report Posted August 31, 2015 Take a look at this thread. I used the Win+1 version and assigned it to a button on my remote. Quote
