3rob3 Posted July 20, 2015 Report Posted July 20, 2015 Hello, Trying to set up FLIRC on my new Nexus Player. I have tried with a Microsoft RC6 MCE remote, and the black Xbox 360 Media remote. It is pretty clear that only every other keypress is received but I can't figure out how to fix it. I have read the tip "Every Second Key Press Doesn't Work" (about recording each button twice) but after trying for many hours yesterday it still is not working. Running the latest GUI and firmware. Can anyone help me out? Quote
yawor Posted July 20, 2015 Report Posted July 20, 2015 Hi, Have you followed the tip correctly from beginning to the end? If yes then it should work. Remember to record the same button at least two times. For example press Up in GUI, press Up button in the GUI and repeat the procedure for the Up right away (without pressing any other key on the remote in the meantime). You can try repeating more than twice (you need to get "already recorded" error everytime you try to repeat recording for the button). Quote
3rob3 Posted July 20, 2015 Author Report Posted July 20, 2015 Hi, Thank you for the response. Yes, I have done the recording repeatedly. It seems fairly random when I will get the "already recorded" message. Sometimes I can record 6 times in a row, sometimes only two. I will try again this evening making sure to do each button repeatedly before moving on to the next button. Quote
yawor Posted July 20, 2015 Report Posted July 20, 2015 That's the problem with RC6 remotes (MCE and XBox). Another problem is that some MCE/Xbox remotes are using unsupported base frequency. I think it's 56kHz instead of 38kHz which Flirc supports. Quote
3rob3 Posted July 21, 2015 Author Report Posted July 21, 2015 So, I cleared the configuration and started over (using Xbox remote) and programmed every button twice. It worked pretty well for a while, then started to miss a lot of button presses. I think I have come to the conclusion that my TV has a lot of IR interference and my problem has nothing to do with FLIRC or the remote. I have had IR issues with my Xbox 360 but always thought that was just due to the Xbox receiver. Now I am realizing it is probably my TV. Thanks for the help! Quote
