Hi, I just received my new flirc, tnx for that!
My configuration is
Zotac ID41 with openelec
A generic remote from an old player
But I've some kind of problem to program flirc
I've the lastest stable app for windows
I select the kodi layout and all buttons works but
power
vol + / vol -
have some problems
If I try to associate the power button, flirc say that the key is recorded but if I try to check pressing the remote power button, the icon on the flirc interface don't blink
If I try to associate the vol - button, flirc say that the key is recorded but if I try to check pressing the remote vol - button, blink the power button, so flirc associated the vol - remote to power virtual buton
If I try to associate the vol + button, flirc say that the key is recorded but if I try to check pressing the remote vol + button, the icon on the flirc interface don't blink
I also noticed that missing the context menu on the flirc kodi interface
Any ideas?
Tnx
J
Could you find out more information on the remote control? Maybe a model number?
Does it help if you record the volume buttons twice? (https://flirc.zendesk.com/hc/en-us/articles/201366933-Double-Key-Presses)
Easiest way to sort this is to use the "Full keyboard" controller and find the keyboard key for contextual menu using the kodi wiki (http://kodi.wiki/view/Keyboard_controls)
Hi, tnx for the reply, I really don't know what kind of remote is, I only know that works.
I partially resolved my problems, I used the kodi plugin, that on kodi remote contains the context menu.
I also recorded the power button with kodi plugin but if I plug flicr on the pc and I try to check the remote buton, don't works!
Now remains only few problems
Vol - Take the power place
Vol + Don't do nothing
I can't program the play pause buton I want to use the same but for now I can't program any of this
Like I said the power is assigned but I don't want to see the power options, so I think that I need to reprogram the map but I don't know what lircd.conf or remote.xml or others?
Tnx, now all works!
I had misread the flirc spec device, flirc is recognized like a keyboard, so I used the full keyboard layout to program the right buton for kodi. So I've installed the kodi addon to edit keymaps, and I've modified the behavior for the power button to suspend action.
