Possibly add the option to record missing and/or incorrect IR commands and add them to existing code sets?
When adding a code set for a pay TV provider I use, I found that the code sets were missing some important keys for navigating the UI. Unlike with Logitech Harmony, I couldn't just record the missing key codes from my original remote as I couldn't find such an option in Skip App, only an option to record an entire code set.
As a workaround, I hunted around for other IR code sets. The Wikipedia article for the pay TV service lists the receiver models they used, and using that I was able to get one of the keys by adding the code set for the receiver model I have, then the other by adding a code set for an older receiver model.
What I basically want to be able to do is to go into activity settings, select a device code set I had already added, and click an option to add additional IR commands (which would stay local to the system the app is on and not get uploaded to FLIRC servers, though I'm not sure if the existing option to learn an entire code set has that option), then name and save those, and use them. In other words, it would be similar to the 'Add or Fix a Command' option that Logitech Harmony has.
