swope1221 Posted February 28, 2015 Report Posted February 28, 2015 Hi everyone, just wanted to say I got everything I wanted to work using latest firmware for flirc and my harmony 650, but can't get the restart command, where you hold down select and play for 5 seconds on the fire tv remote duplicted. I tried using the ok and play buttons I had mapped on my harmony using the amazon fire controller gui and I even tried the full keyboard and mapped control alt and delete to a button. I tried just pressing and releasing the button and holding it down til the fire rebooted, but it never did. Any idea on how to map this command? Thanks. Eric Quote
yawor Posted March 1, 2015 Report Posted March 1, 2015 Unless the FireTV implemented some keyboard combination to do the restart I don't think that this is possible. You can hook up an USB keyboard to the FireTV and test different key combinations. Maybe one of them will result in reset. Quote
