jaymillerSR Posted February 13, 2015 Report Posted February 13, 2015 Is the thermal pad double sided? Do I peel 1 side off or both sides Peel off on the pad? Quote
Chris! Posted February 16, 2015 Report Posted February 16, 2015 I had no idea so I asked Jason: One side of the pad is sticky, you need to peel both sides off though. Quote
dcomander Posted February 17, 2015 Report Posted February 17, 2015 Does the sticky side go against the chip or the case? Quote
Chris! Posted February 18, 2015 Report Posted February 18, 2015 It doesn't matter as it functions to connect the CPU to the heatsink - the heatsink in this case being the case (or built into the case). Quote
philelzebub Posted August 8, 2016 Report Posted August 8, 2016 I'm having similar issues with this...One side of the pad is sticky, you need to peel both sides off though.I've removed plastic on the sticky side and placed it on the heat sink. The other side of the pad feels like paper, though, and I can't seem to be able to remove it... any help? Quote
yawor Posted August 8, 2016 Report Posted August 8, 2016 There's only one sticky side. You don't need to do anything with the other one. Quote
