26196008 Posted January 9, 2015 Report Posted January 9, 2015 Hi, I'm trying to get the flirc (3.4) running together with the Windows media Center and the Logitech Hub. The normal Key (Cursor keys and 0-9) are working fine for me, BUT all Special keys combinations are problematic. If I set Inter-Key Delay lower than 5, then the WMC receives ALL key twice or never. Is the Inter-Key Delay greater than 4, then the normal keys are working fine. Keys like CTRL+O are only works sometime. The suspend button needs a Long-press instead of a normal short-press. Does somebody have a similar experience and hopefully a solution for this? Thanks in advance Marc Quote
