cliveb Posted February 15, 2024 Report Posted February 15, 2024 I have had a FLIRC USB (v2) for years. Today it stopped responding for no apparent reason. I swapped in a FLIRC USB (v1) that I also have, and that is working fine. So it's not the computer's USB side of things. The machine it's plugged into is a MythTV frontend that does not install any updates, so there hasn't been a firmware update. And it stays powered on 24/7 - it hasn't been rebooted. I took the unresponsive FLIRC to my laptop to see if the FLIRC configuration utility could do anything, but it just says "disconnected". Running FLIRC_UTIL says "device disconnected, can't run command". Looking in Windows Device Manager, it doesn't show up at all as a device when plugged in. So I guess it's just spontaneously died. But before I buy a new one, is there anything else I can try? Quote
rtessenear Posted March 2, 2024 Report Posted March 2, 2024 I have the same exact issue. My FLIRC V2 has been working without issue, I unplugged it and plugged it back in and now it's saying disconnected. I moved it to two other Win 11 PCs with the same results. I also used a Mac to see if a UNIX based OS would see it. No luck. Very strange. Your issue on Feb 15th and mine on March 1st. Quote
cliveb Posted March 2, 2024 Author Report Posted March 2, 2024 Thanks for your follow-up. I didn't unplug and replug my FLIRC. It was permanently plugged in to the MythTV frontend (a Linux Mint machine) and it just stopped working one day. Since I didn't get any suggestions for other things to try, I just assumed it was dead and bought a new one, which is working just fine. FYI: I found that The Pi Hut appear to sell it for less than everyone else. £19 from Pi Hut, typically £30 on Amazon, Ebay, etc. (I'm in the UK). Quote
