Setting up 1s with Nvidia Shield Pro
Dear all,
I just got my 1s today and have been unable to set it up it with Nvidia Shield Pro.
Here what I did, kindly correct me what I got wrong.
I connected the 1s to my PC via the USB. I downloaded the USB Flirc App and got the firmware upgraded to v4.10.2. Then under Controllers Tab, I chose Nvidia Shield Gen 2 and hit the Go button. However, when the app showed me the steps to record the button, I could not get the 1s to recognize it.
Did somebody encounter the same problem? If you did, could you help me to fix it up.
Thank you,
Edited by minhksb
You need to choose flirc on the skip. Make sure your flirc usb is in line of sight. Best to use a USB extension cable from the shield.
