Solomalee Posted November 4, 2023 Report Posted November 4, 2023 (edited) Hi folks, This is more of a How to for the new Skip 1S, but there is a bit of Flirc USB info in here too...(Dear Moderators - Apologies in advance - I also posted here the same information - feel free to move my post to a more suitable location if necessary) I received my nice new Flirc Skip 1S remotes yesterday and excitedly got down to setting them up on my ‘most straight forward’ configuration (A TV and a Kodi Box). An hour later, I was stumped. After a few searches on the forums, I didn’t find any obvious fixes, so I spent a rainy Saturday figuring this out for the community. Here are my conclusions and also a few Bug Fix requests for the Flirc team at the end... My configuration MacBook Pro OSX 13.5.2 Kodi 20.2.0 Flirc Skip App 0.9.954 Flirc USB App 3.25.3 YouTube Video showing the same method can be found here Steps to configure Flirc Skip 1S for Kodi, including PVR and other ‘missing’ commands Delete all configurations from the Flirc Skip 1S remote and delete the remote from the Skip App Connect Flirc USB to a USB port In the Flirc USB app select the Kodi Controller In the Skip App, Use the wizard to configure an activity using the wizard as follows: Activity A: Media Center PC > Kodi Add Devices: PC > Flirc - Kodi PC > Flirc - Windows Media Center Map the Kodi device to the controls for Navigation, Media and Audio Choose the Buttons panel and make the following modifications Power Button: Power Up: Remove any Power Up commands Power Button: Power Down: Removed any Power Down commands Record Button: Map to the PC: Windows Media Center - RECORD command Channel Up Button: Map to the PC: Windows Media Center - CHANNEL UP command Channel Down Button: Map to the PC: Windows Media Center - CHANNEL DOWN command Home Button: Map to the PC: Windows Media Center - GOTO GUIDE command (This is a personal preference given the lack of a dedicated Guide button) Synchronise the remote. At this stage, there is one button that still won’t function, the STOP button. To enable the stop button… Open the Flirc USB app Pick the STOP command in the Kodi controller (you will be promoted to record an IR command) Press the STOP button on the Flirc Skip 1S remote (the STOP IR command should now be mapped to the Kodi command for STOP) Grab a beer, popcorn or nachos and enjoy a fully functioning Kodi remote Hope at least a couple of folks find this interim solution useful. Now for the Bug reports BUG: Skip 1S Flirc - WIndows Media Center device has the command GOTO RECORDED TV mapped to the record button: FIX: Change to the RECORD Command BUG: Skip 1S Flirc - Kodi device is missing various IR codes and respective Kodi action mappings: FIX 1: Please add PC: Windows Media Center Record Button IR Code to the Skip 1S Record Button and map to the respective Kodi RECORD action [R] FIX 2: Please add PC: Windows Media Center Channel Up IR Code to the Skip 1S Channel Up Button and map to the respective Kodi PageUp action [Page Up] FIX 3: Please add PC: Windows Media Center Channel Down IR Code to the Skip 1S Channel Down Button and map to the respective Kodi PageDown action [Page Down] FEATURE REQUEST: Please add PC: Windows Media Center TV Guide IR Code and map to the respective Kodi TVGuide action [E] Solo Edited November 4, 2023 by Solomalee Quote
