Flirc, Harmony, Kodi and Suspend
crutonbn
If you have been wondering on how to make Kodi work with Flirc and Harmony remotes to automatically suspend without you having to call up the shutdown menu or be stuck with the other methods that limit suspend commands to the home screen of Kodi this is how to do it with Kodi v15 at time of writing. Thx to GoodOmens for the tip though his info is a little out of date now so this is a guide on how to do it all.
Kodi/Openelec
Go to system information and make a note of it's IP address
Turn on SSH in Kodi services
Harmony Software
Devices
Flirc Media Player
Change Device Settings
Power Settings
I want to turn this device off when not in use
I press the same button for on and off
Add command and select PowerOff (if you have messed with poweroff before finding this guide choose the fix command and reset IR code for PowerOff)
Sync remote
Go to Flirc software
Select file clear configuration
Select full keyboard
Select Ctrl+F12 (as Kodi wont respond to this at least not yet)
Go to devices on Harmony remote and select Flirc media player then hit the power off key to map it to Ctrl+F12 (requires harmony with display screen or map power off to physical button)
From Windows
Download WinSCP
Select SFTP
Input Kodi IP address
Username = root and password = openelec
Once logged in select options\preferences\panels and tick the box for “show hidden files”
Browse to /storage/.kodi/userdata/keymaps folder
Create a file called remote.xml
Copy and paste in the text below, then save (old floppy disk icon)
<keymap>
 <global>
  <keyboard>
   <f12 mod="ctrl">XBMC.Suspend()</f12>
  </keyboard>
 </global>
</keymap>
Exit WinSCP
Kodi/Openelec
Reboot the system (required for new xml to take effect)
Now if all goes well when using Harmony activities the system should go into suspend.
If you've been wondering why not just use the stock Flirc/Kodi power off command combined with the Kodi settings\power saving changing it from shutdown to suspend, this doesn't work. If you go this path the system will always wake up when using any activity and not go into suspend, the stock power off command is bugged somehow like it's being sent multiple times.
Edited by crutonbn
I'm running Kodi 15.1 with Windows 10.  I have the "wake" function from suspend working with a Harmony One.  I want to try your solution for a "suspend" function but I am a real beginner. What is "SSH" and where under Services do I find it; I looked for something like it but didn't recognize anything it might be.
Sorry for what is probably a silly question..
http://lmgtfy.com/?q=what+is+ssh%3F
and to atone for that
http://kodi.wiki/view/Settings/Services
  • 6 months later...
This has been a very helpful thread - many thanks to CRUTONBN for taking the time to document this. This would all work very well if it didn't make the assumption that the MyHarmony default settings for the FLIRC/Kodi device included the keyboard "ctrl-F12" for the PowerOff command. Several other threads which I read also indicated that this was now part of the MyHarmony profile for the device. But it was not the case for me... and I have a few grayer hairs because I didn't validate this first.
I followed the directions to a T, but selecting PowerOff always resulted in the Kodi shutdown menu. I'll spare the reader the variety of things I tried and get to the punchline: MyHarmony put the keyboard "s" for the PowerOff command. I finally validated this by watching the keyboard in the FLIRC software while I pressed the PowerOff button, yep, "s" lit up.
The quick resolution was to the change the line:
To:
<s>XBMC.Suspend()</s>
Bliss at last! Now if I could just figure out why my Harmony activity of turning on the TV, Amp and Kodi takes SO long before it exits and I can use the buttons... But that's for another forum.
Edit:  OK, using the s key wasn't ideal since whenever I needed to enter text in Kodi (search function etc) if I hit s it would suspend. lol  I remapped the PowerOff command on the remote in FLIRC to ctrl-F12, so I'm in line with the "standard"
Cheers!
Robert
Edited by Phydeaux
Additional Information
  • 1 year later...
  • 6 months later...
I followed the OP and got this working in suspending and waking up my Windows 10 box with Kodi.  But during the suspend time, any Harmony hub activity or even without Harmony hub activities, the Kodi box will wake up...  I thought by making an xml file as described by the OP, this won't happen.  I am running the latest Krypton release of Kodi.
Any ideas?  Thank you.
Now both wake and suspend stopped working... LOL  This has been a very frustrating and confusing experience so far, to say the least.  I think for now, I'll just turn the HTPC on and off manually...  Thinking about trying the SE though.
Edited by DE2000
