Problem setting up flirc after updating
adishtrt
I buy my FLIRC a few months ago and all good and well....today i wanted to upgrade the firmware and set the remote with the updated FLIRC....
it seems that for example, when i set my 2 key on the remote and select the number 2 on the "full keyboard" in the flirc app... and then select the 5 key on the remote it show me an error that the button is already exists....
i'm using the xtreamer ultra remote: https://shop.xtreamer.net/products/Xtreamer-Ultra-Remote-control.html
thank you!
It's been a while since i've been the forum but I thought there was a similar issue that had a solution. Unfortunately I couldn't find that.
If you open a text editor (or anything you can type text in):
- when you press "2" on your remote what key is outputted on the screen?
- when you press "5" on your remote what key is outputted on the screen?
Just to check what key Flirc thinks already exists.
After you upgraded, did you clear the configuration before reprogramming?
https://flirc.zendesk.com/hc/en-us/articles/203361609-What-does-Save-Load-Clear-Configuration-mean-
  • 4 years later...
nothing is shown on the screen. The B&O Controller is attached with software to an IR output
