Heads up - interference from other sources than your remote
Segfault
I fought my problem for a long time, years, erratic response to key presses. I thought distance was the culprit, although 12 ft shouldn't be a problem. I used a USB extension to connect Flirc to mitigate this issue. Until I finally found the source of problem - an 8-port network switch. Both the Kodi frontend and the switch are mounted to the wall, about 2 ft apart. Flashing LED-s of switch were the source of "noise" which obviously interfered and saturated my Flirc adapter. After I turned the switch 90 degrees so the LED-s no longer shine into my Kodi frontend the problem was completely gone.
