bigmike678 Posted November 14, 2019 Report Posted November 14, 2019 I would love to see an updated case that makes direct contact with the usb controller as well as the processor. the usb controller puts out quite a bit of heat as well. thank you Quote
PeMo Posted January 2, 2020 Report Posted January 2, 2020 I think that would be great - I'd love to see one that allows for HATS to be installed stealthily - modify the design to lower the entire metal area over and between the HAT mounting holes to a lower flat level that still contacts the CPU and USB controller (with slots for camera and display ribbon cables plus the POE header). Given the Pi 4 has such low connectors you would probably not normally need a GPIO riser to fit one. The plastic top would still be level, but could extend down three sides if the 'shelf' makes it too hard to cast. Status displays, TV inputs, UPS batteries would all love this option, and if you didn't need it you can always install a heat sink (or fan) to further help cooling as the top will still cover the void. Throw in a 3D model of the plastic bit (so people can print their own custom tops for taller hats) and you have a makers dream case ;) If someone has a mill they could probably mock it up... anyone? 1 Quote
Endgame Posted June 3, 2020 Report Posted June 3, 2020 My request would be for an aluminum clip on top that could replace the soft touch plastic top. I’m currently using FLIRC cases for Pi 4s running scientific processing (boinc rosetta@home). Since all 4 CPUs run 24x7 (And I have them over volted and over clocked to 2100), it can get quite warm. Removing the soft touch cap knocks about 10c off (70c to 60c) and just resting a heatsink on the top (on old Thermaltake volcano 6cu) takes off another 8c. I imagine a clip on, small finned, aluminum top with a little cheap thermal paste would keep the temps around 55c passive and much less if you pointed a fan at it. Here is hoping someone reads these posts! Quote
Jay Rowe Posted June 26, 2020 Report Posted June 26, 2020 I love the present configuration of the Flirc Case, but I think it can be improved greatly. One of the things I like less about the raspberry pi configuration is the mess of cables. I recently purchased an Argon One case and I really like it. In fact I considered replacing my Flirc Case with it until I realized that the USB ports now come out the back, thus rendering the remote sensor inoperative. The obvious solution is to have one of them routed by a hat to face front and have the sensor actually be embedded in the case facing the user or similar. As Pis become more powerful I see more people turning to them for more things. In my opinion the Pi still needs a lot of work done in the case area and I personally prefer the aluminum cases. These are just my thoughts. What are your thoughts? Quote
douglaslucas Posted July 4, 2020 Report Posted July 4, 2020 I think it would be amazing if a new Flirc case came out for the Pi 4 that provided easy access to not just the GPIO sockets, but also the camera and touchscreen sockets. Any news about whether this possibility is upcoming and if so, when? <3 Quote
rakhamlerouge Posted February 9, 2021 Report Posted February 9, 2021 > Throw in a 3D model of the plastic bit This! Top and bottom plastic bits please! <3 Quote
