July 31, 20179 yr comment_14073 Hi, I just bought a new v2 Flirc and was trying to set it up to work with my harmony 650 to control my fire tv stick. I was unable to find any definitive answer as to whether the Flirc works the Fire TV stick or not. If it is, can someone link me to the correct method to do so? Thanks in advance. Edited July 31, 20179 yr by veeram Report
July 31, 20179 yr comment_14075 If you have a working OTG cable, then it should work. You need to turn off USB debugging otherwise the OTG won't work. Report
July 31, 20179 yr Author comment_14077 Gotcha thanks ! So a cable like https://www.amazon.com/Micro-Cable-Power-Samsung-Player/dp/B00CXAC1ZW should work ? I see review comments by folks saying it works for the Fire TV Stick (with alexa). Would it just plug-n-play or does it need any other work after I have the Flirc connected to the OTG cable to the Fire TV Stick ? Report
