Raspberry Pi System Shutdown
Hi
I am setting up two Raspberry Pi 3's to be used as media players connect to a projector in the ceiling which will be mostly inaccessible.
Can i use a Flirc IR Usb with a remote to shut down the raspberry Pi, I know it won't power up the device but I have a separate wireless power adapter to kill the power and switch it back on.
While the video is playing I want to map two Raspberry Pi terminal commands to one remote control button press.
first is
sudo supervisorctl stop video-looper
 which I have shortened to
stopvid
then the normal shut down for Raspberry Pi which is
sudo shutdown -h now
Apologies if this is posted somewhere else already.
Cheers. Richard.
